Clean Beatsource Songs turn into Explicit
  • Device model iPad 5th Gen
  • Version of operating system 18.3.2
  • Version of djay 5.2.9
  • Hardware/controllers used Reloop Mixon 8 Pro
When I add Beatsource Clean edits, especially ones with intros, the Playlist sections turns them into the Dirty versions. The songs say “Clean” but it has the curse words. It messed up my set I made at a live event. The songs are clean inside of Beatsource. But Djay playlists turns them into Dirty versions. At this point the Playlist function is useless for Beatsource.
Hi @E_Flem, sorry to hear you experienced this issue. Hopefully you were able to remove the offending vocals quickly with Neural Mix.
  1. Can you please share the exact track IDs so I can test this on my end?
  2. Were you playing the song from the Beatsource Source in the djay Library or from the My Collection Source?
  3. Do you have both the Clean and Explicit version of this song in your library?
  4. Do the Clean and Explicit versions have different song titles?
  5. Are you using the Offline Locker? If so, are both the clean and explicit versions in your offline locker?
Basically every clean version of any song came out as the explicit version when saved to the “Playlist”
My Collection Playlist
I had both versions saved in Beatsource folders
Both Versions have the same titles
The song was labeled “Clean” but it was an Explicit version when played.
I wasn’t using offline locker
Thanks for the additional info @E_Flem. I have passed this onto engineering to see if they have any suggestions.
  1. In the meantime, if you remove the Explicit Versions from your library, does that solve the issue?
  2. What if you add the Clean Versions to your Offline Locker, but keep the Explicit version still in your library - does that solve the issue?
Haven’t tried, don’t want to take any chances.
It was quite embarrassing preparing a clean set and curse words kept popping up.
Hi @E_Flem, our engineering team was able to replicate this issue and is investigating it further. In the meantime, they recommend only adding clean versions to My Collection until this can be addressed.
Thanks for the help with the issue
You’re welcome @E_Flem
Summary of the issue:
How to reproduce the issue:
When adding an explicit song from beat source to a playlist it turns the explicit song clean. And I’ve noticed some clean versions turn explicit. This is a huge bug that needs to be addressed. When playing a song I want to be ensured it’s the actual song I’ve added from beat source.
iPad os 18.3.2,
Shop version 5.3
Reloop buddy
Hi @Nicole_DiMinico_O_Ne, welcome to the Community! Please use search before creating new topics. I have merged your new topic with this existing one. This is a known issue - please see above. The current recommendation is to only add clean versions to My Collection until this can be addressed. Thanks!
Hello,
It’s been months and multiple updates, and the problem is still persistent. This makes playlists and Beatsource locker useless.
Thanks for the follow up @E_Flem. Unfortunately the dev team hasn’t figured out a solution for this yet. The recommendation remains to only add the clean versions to your library until a more permanent fix can be implemented. Sorry I couldn’t be of more help.
Android OS 15 version. Youtube vanced other app less kindly need your
Hi @2asd, welcome to the Community! Can you please rephrase your comment? I’m not sure what you mean. Thanks!
Clean Beatsource Songs turn into Explicit. Remove explicit filter content. Kept clean ,i have is youtube vanced issue other third parties
Did the new update fix this problem?
Hi @E_Flem, no, this was not included in the 5.4.3 update. The team is still working on a potential solution.
Please for the love of all that is holy implement a software that can accurately detect and differentiate clean and explicit tracks. I will have an explicit song in my library and when I play/load the clean version even ONCE or add it to my library it overrides the explicit version and will only play the clean version from then out. I have and need both versions for different events/contexts and would love to have both in my library without them destroying each other.
Hi @Mmarvin, I’ve merged your new topic with this existing one as they are closely related.
There is a new bug of Beatport playing the explicit version instead of the clean version. Very unprofessional and embarrassing. It says ”clean” but play the dirty version
It only happens with intros.
Djay 5.6.5
iOS 26.5.1
