Clear tracks before launching Automix
How can I clear all tracks on decks BEFORe launching an Automix? If I have played tracks before, the automix finishes playing them, THEN starts.
I want to start Automox from a blank screen even if I have played stuff before.
Is there a ipad shortcut ou command?
Tap and hold the load button and select “Eject” from the pop-up menu. You need to do this for each deck.
OK, thanks for the tip.
