If youâre okay with manual work, you can always copy the contents of the djay folder from the Files app (under âOn my iPadâ) from one iPad to another.
Youâre right to throw in a word of caution here, @sooteee, since not all settings will be transferrable. This especially applies to playlists and songs added to the âMy Libraryâ view. Still, analysis data should get transferred this way, along with old recordings, MIDI mappings and settings.
@djjoejoe and @sootee - thanks for the suggestion. It does appear that cueâs and midi mappings got transferred by copying the local âon my iPadâ contents to a new iPad.
Unfortunately music analysis data and regular settings did not get transferred. Cues usually get saved to iCloud anyways so Iâm not sure if copying the contents from one iPad to the other really did much.
Source iPad shows that djay is using 1.67GB for Documents & Data. The âdjay/User Data/djay Media Library.djayMediaLibraryâ is only 227MB.
However, just as important as cueâs are the playlists and songs added to My Library. How can I transfer these? Got new iPad Pros to go with our new RANE Twelve MKIIâs and itâs a lot of work to duplicate the My Library from one iPad to another. These are critical because I have songs from Tidal, iTunes, Soundcloud and Files combined into various playlists in the DJPro Library.
If youâre using iCloud, shouldnât that allow for the transfer of all data in the same form, from one iPad to the next? It works seamlessly in that way for me when I go from iPhone to iPad
Currently - track metadata generated while using djay on your Mac, iPad, or iPhone is automatically synced via iCloud. This includes cue points and loop regions per song. Other metadata like BPM analysis is currently not synced.
