How about color coding for saved loops also to correspond with saved cue point.
Hey @MontyJoe ,
Thank you for posting this as a suggestion here in the Community. We appreciate your input!
Could you elaborate a bit more on this, especially how the color-coding would work with both loops and cue points? Maybe add one or two examples?
Cheers!
For example my first cue point is always green color. So if I use that cue point as a loop then it should also be green color. I always use my cue points as loops also.
Hey @MontyJoe ,
Thanks for clarifying
I will pass this information on to our Dev Team and keep you posted with any available updates on the topic.
Cheers!
