Hello there,
i love the app so far and use it as my choise after getting back into djing.
One thing i‘am missing are colored memory marker.
No need for them to work as a cue i only want to set some visual marker and don‘t waste my hot cues on this.
A set of 8 in the same colors as the hot cues would be my suggestion. To keep them appart, the hot cues could stay triangle and the memory ones rectangular.
Thx for reading
I second this. Very important feature lacking in Djay Pro. If not this exact feature, any way to mark phrases without tying up hot cues would be amazing.
I’d wonder if that might be something that could be AI’ed? Like surely for vocal tracks you could identify a chorus (most commonly repeated vocals), verse (non-chorus vocals), intro (non-vocal bit at the start), outro (non-vocal bit at the end), instrumental sections (non-vocal bit in the middle).
Know you can kind of do that anyway via the waveform but it would be quite cool if Djay Pro could automatically highlight these parts and maybe use them for automix itself.
But maybe for now just being able to map them manually would be very cool
Pretty sure Rekordbox has AI phrase analysis. I don’t even care if Djay Pro analyzes it for me, I’d just like to be able to put more markers on my track. I can’t remember shit anymore, I need all the crutches I can get.
I second this. I think this is just about the only thing holding me back from going all-in with DJay Pro isntead of it being relegated to casual listening and wedding ceremonies.
This is one thing I started using more often in other DJ software.
Helps you when you quickly glance on to the screen to remember what up (orange - good looppoint, yellow - bridge, purple - point for outro with vocals etc).
I wouldn’t say this is very important. As it’s not essential to perform basic DJ skills. But it’s helpful.
Hello everyone! We are happy to report that an additional 8 hot cues have been added in the 5.4 release. We have also added Cue Loops which allows you to store loops in the hot cue panel.
Cue Point Banks: Set up to 16 Hot Cues per track
Cue Loops: Added ability to save loops as Hot Cues
Expanded Cue Point color options: choose from up to 16 unique colors per Hot Cue
