No puedo usar el controladoer en la versiómn premium, mi controlador es la Numark Dj2GO2 Touch
Hay algo que pueda hacer?
Instalé el software en Tablet Samsung
I can power the Numark DJ2Go2 Touch with an iPad, but I needed to use a 1x USB-C → 1x USB-A adapter. Any more USB-A ports and there wasn’t enough power.
This drains the battery quickly though (like 4hrs max play for me) so maybe 1x USB-C → 1x USB-A + 1x USB-C (power only) … Then you don’t run out of battery ![]()
