Compatibility with the Pioneer DDJ-SX2
Hey, everyone out there.
I really like the layout of the Pioneer DDJ-SX2 as there are plenty of imputs at the rear so I can plug my Technics 1200’s and CDJ’s, if freinds bring vinyl or CD’s to the party. Also the sound output on this mixer will be good if plugged into a big sound system no doubt… So, can the Pioneer DDJ-SX2 be re-mapped to use the Djay Pro softwear ?
Many thanks, Adam
Generally speaking, you can map any MIDI controller to djay Pro.
Awesome mapping, but my CUE doesn’t work??? HELP!!!
Guys,
We’re happy to announce that djay Pro now natively supports the Pioneer DDJ-SX2!
Get yourself the latest update of djay Pro at the Mac App Store and check it out!
Hi Warren , is it easy to map a controller like this to djay pro ? I just want something simple to use & pick up with djay pro. O.k. let me put it another way , what few midi controllers of this level of sound output , what would you recommend ? Thanks Adam
Ignore this ,checked it out today and it maps ok…
Do you have a mapping for the ddj SX2 with DJay Pro software?
I can’t map the: Master Level, Booth Monitor Level or the Headphone mix. Do you think that there is something wrong with my SX-2 controller?
