Compatible with iPad 2 with a 30pin to lightning adaptor on the Philips mx1-dj?
Does this setup work? Ipad 2 with Djay 2 connected via 30pin to lightning adapter to a Philips Mx1-dj?
Hi Allan,
Sorry that doesn’t work, the adapter only works the other way.
Hi, just tried using a lighting to 30 pin adaptor on my iPad 2 and it doesn’t work, doesn’t even show charging, adaptor is working as I’ve tested using iPhone charging wire.
