ive tried moving djay to the trash but when reinstalled it uses previous saved settings. ive tried this. "
Depending on your version of djay please copy and paste the following command into the Terminal and press “enter”:
djay Pro (downloaded from the Mac App Store):
defaults delete com.algoriddim.djay-pro-mac"
but doesnt work saying domain not found and defaults not changed, how can I reset it or completely remove? look forward to helpful replies. thanks
Hey Kevin,
I can help you, I’ve done this and it works,.
Djay Pro or Djay Pro 2?
Finder/Applications/Right Click Djay Pro/Move to Trash
Select this link Below, Open “Finder” move the curser to the top,
Select Go/Go to Folder and paste the link
~/Library/Containers/com.algoriddim.djay-pro-mac/Data/Library/Application Support/Algoriddim
(Add “2” after djay if you have Djay Pro 2)
This link will take you to “com.algoriddim.djay-pro-mac” folder.
3. Delete Folder
4. Empty Trash
Note: Always Back Up Folder Externally Before deleting and Emptying Trash.
