Configuring sample pack with Pioneer Dj DDJ200 controller
How do i configure sampler pack on pads of Pioneer dj DDJ200 controller with windows pc ?
Hi @King_Addis,
Thanks for the question!
Could you share in a bit more detail what you mean by the configuration of sampler packs?
Hi Nathaniel,
Thanks for your reply.
I am just setting up the controller and i want to play sound effects (from the sample pack) by using the Performance pads on the DDJ200. So the question is how do i match that on the controller ?
Hi @King_Addis,
Thanks for the clarification!
This looks to be a simple case of MIDI mapping your controller appropriately. Please visit the link below for more information.
All you need to do is press the pad and assign the appropriate target and action.
Hope that helps!
