I am currently trying out your DJay beta for windows and it is every impressive as a software. I am currently using an pioneer controller ( Pioneer XDJ-AERO) which isn’t on your supported controllers list. Is this something that is likely to expand when the full version is out? Or will more features be added to manually converting over such as exporting pioneer updates?
James
