Connecting Djay 2 iPad to DJ Controller
Firstly, you guys are awesome, keep up the great work.
I’m assuming I’m not the only one out there who wants badly to use their DJ Controller (in my case a Reloop Terminal Mix 4, compatible according to algoriddim) with djay + spotify. Since spotify integration for Mac is currently unavailable, I’m wondering if there’s a way to hook up djay on the iPad with my TM4. I know it’s doable with the Reloop beatpad, but is it possible with other compatible controllers given some sort of cable?
Hi Jeff,
The Terminal Mix 4 is not supported with djay for iOS, sorry. You can only use the controllers listed here: http://www.algoriddim.com/hardware
I bought the day for android, it seems like the xw-j1 is the only controller I could use. But it isn’t available anywhere reputable. Can I buy one from you guys directly?
