Hey guys! I’ve tried searching for this but an exact answer didn’t come up.
Normally when I play clubs where they have a huge mixer like Pioneer CDJ2000 I play from a USB, and if I play bars I bring my computer and my portable Hercules Mixer.
Next month I got booked for something where it’s big pult (the CDJ2000) and I wanna bring my computer, as I need to use Spotify for this.
My question is - how do you connect the 2? Like which cables do I need to bring and which inputs and outputs do I use? Is the syncing stable and reliable?
You can’t use Djay Pro with CDJs as far as I’m aware. You might be able to get mappings for your Hercules controller. Hoping someone else on here can help you or confirm that.
the CDJ2000 are natively supported by djay Pro, also if your mixer is having an external mixer, i would recommend working in that mode with the two CDJ2000. You can find detailed info about setting up the CDJ’s with an external mixer in the djay Pro manual (cmd + ?).
Thanks for your reply again! I just need one thing clarified - just so I don’t show up there and the cables are missing. You’re saying I need 2 usb cables? Like this one? (Usb to usb) https://images-na.ssl-images-amazon.c…
And they go in my Mac’s 2 usb ports and then one in each of the decks?
