Connecting IDJ Pro 2012: 30-Pin to USB-C iPad
  • Device model (e.g. 2025 iPad ):
  • Hardware/controllers used (iday pro 2012)
  • you can suggest a cable or an adaptador that can connect usb 30 pin iday pro to usb c port of ipad? i still have 30 pin adaptor to usb lighting and works on my ipad version 2014 and everything works. i 've bought usb lighting to usb c adapdator but the iday pro doesn’t connect to my ipad version 2025
Hi @Studio_Fucci, welcome to the Community! There are several USB-C to 30 Pin cables and adapters available on Amazon. However, these are all 3rd party cables; Apple doesn’t manufacture an official cable for this. In my experience, some of these 3rd party adapters/cables work and some don’t. I recommend you read through the reviews and try to find a high-quality one from a reputable manufacturer. Definitely don’t buy the cheapest one. I hope that helps.
Good morning
Thank you so much for your reply. I’m wondering if you can tell me which adapter you know can transfer both data and power. The ones I’ve identified don’t offer any guarantees.
You’re welcome @Studio_Fucci. I don’t know for sure. I’ve never personally used any of them.
