Connecting Numark Platinum FX to Phone
Your question:
I just purchased a Numark Platinum FX Controller. I have been trying to connect it to my iPhone 13 to use with the DJ Pro software. I purchased the camera Adapter to connect the controller to my iPhone and it doesn’t work. I need another source of power, not just the iPhone charging. Can someone please tell me which Dongle to get so I will be able to connect ??
Hi @DJEXTRO, welcome to the Community! When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
  1. Can you please confirm that you are using this genuine Apple adapter: Lightning to USB 3 Camera Adapter - Apple
  2. Do you also have the adapter connected to power using your original Apple charger and cable?
Hello, Thank you :pray:t4: for all your help. I figured the problem out. The problem wasn’t with the connection of the Numark Controller. The problem was that I purchased a USB Camera adapter that was not compatible to use. I had to reorder a Certified Apple :apple: Camera Adapter to connect the controller to my iPhone.
Thanks again for your help !
Perfect. Thanks for the follow up @DJEXTRO. You’re welcome!
