Connecting speakers to ddj srt 1000 with djay on Ipad
Hello,
I´ve connected my ddj srt1000 to my Ipad pro to use with djay.
Everything works fine but i can not precue the tracks with my headphone via the controller.
Also i can not connect speakers to the controller to use as audio output.
Is there a way that i can solve this?
Thx in advance !
JC (Belgium)
Hi there and welcome to the forum. firstly, that is a really nice controller congratulations. do you have split output enabled in settings. Try that with regards to pre-queueing through the headphones
Ok,
I Will try that tomorrow, so it´s not possible to pre-que directly from the
controller?
(Like if we use a laptop and dj software like serato)
Grts JC
Ok,
controller?
Grts JC
Ok,
controller?
Grts JC
Ok,
controller?
Grts JC
Ok,
controller?
Grts JC
Ok,
controller?
Grts JC
Hi yes it is you just have to enable the setting
Ok,
controller?
Grts JC
Hi there. For some reason your posts are also replicating multiple times. I forgot to answer the second part of your question regarding playing through the speakers. Once the controller is connected check the output setting and make sure it’s not on the iPad but on the controller
Ok,
controller?
Grts JC
I´ve tried every possible setting and still not working .
Could you ,Just to make shure , send me all the settings and midi settings
thru?
So that i can verify that i´ve done all the settings correct?
Thx!
thru?
Thx!
I am so sorry but I do not have the midi settings for that controller. have you tried reinstalling the application
thru?
Thx!
