Have a look or/and ask a support from AH. I feel that should be work. Maybe you use a wrong connector.
Hi all, I wanted to mention, that I just recently got myself a K2 and was facing the same exact issue. The immediate solution is to update the firmware on K2 to the latest version 2.5, that is a known issue while using K2 with modern non-intel macs and was fixed with this firmware update.
Thanks for sharing @Akrilovy
- Device model: Iphone 13 Pro
- Version of operating system: 18.5
- Version of djay; Newest
- Hardware/controllers used: Allen and Heath Xone K2
Hey,
I have used my traktor kontrollers a fair bit with my Iphone and they work great, but for a smaller system I was wondering if using only my K2 would work. I see that other people have talk about using it with ipad and in tandem with other controller, but I am wondering if it works alone. I know I need a Lightning to USB adapter with the usb C power. Is there anything else i should know or need. Thanks!
Hi @Ole_Kvalvaag, welcome to the Community! Please use search before creating new topics. I have merged your new topic with this existing one. Please refer to the discussion above. I hope that helps!
