*Hi, I have a Ddj Ergo pioneer console, connecting it to the iPad with the DJAY app everything works but I can’t release the audio via Bluetooth, how can I solve it? If I disconnect the console, everything works, but if I connect it no longer works.
Hi Tony,
It’s not currently possible to send out the audio to a Bluetooth device when the iPad is connected to an audio soundcard. You’ll need to connect your speakers to the master output of your controller. However, I’d like to point out that we are currently looking into ways to support this. We kindly ask for your patience while we do so. Thanks for your understanding.
Cheers, G
Grazie spero presto risolvi e complimenti per tutto , grazie ancora
