Controller stops working after 10 mins
i am using this on a macbook air and for first 10 minutes everything works fine then all of a sudden the midi controller (Pioneer DJ Wego) stops working. The lights on the controller stay but the function stops - you can only use the computer to control it.
Any ideas?
Hi Jamie,
Sorry to hear that. Which djay version do you have? Also, did you perform the firmware update for your controller?
