Controllers Jogs response with Djay Pro
Pc, Windows, Numark / Next beat, lastest Djay version
I notice that Jogs are not so responsive with Djay Pro, when you turn it to find a specific point on the track
Regards
Hi @JustineB, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Yes, I’ve noticed this with a couple of controllers when I compare the response when using Serato. I first noticed this with the Denon LC6000 and I also notice it with my Rev5. It works well, but when you load Serato, it works much better. I notice it more when scratching and beat juggling. I’m not using Windows however. I am usually using it with my Macbook Pro or iPad. I know that djay Pro gives options for changing the jog wheel in the MIDI section but I haven’t had much luck getting it as responsive as Serato which has no adjustment to make.
It has been done thanks
Could you confirm you have iCloud Sync turned off?
This is a known issue at the moment that relays to responsiveness and lag within the software.
Not using Icloud since it runs through Windows
I was able to get my ddjsr2 almost as tight a Serato. Had both running at the same time on 2 different computers. Just played around with the settings a bit. I haven’t tried it with my rev 5 yet. It is definitely something that should be addressed.
Fine, Djay pro settings please ?
Sorry I missed the part where you wrote it was Windows related
:clap: :clap: :clap:
Thank you @Five-0
Thanks for that @Five-0!
