Hello there,
I have been using djay Pro AI on my iPad for a while now and absolutely love its intuitive interface and features like Neural Mix. It is been a game changer for my casual gigs and practice sessions. Although; I am considering transitioning to djay Pro AI on a MacBook for a more powerful setup and a larger screen; but I have a few questions and concerns.
Are there any features on the Mac version that significantly differ from or improve upon the iPad version? For example; does the Mac version have better performance for Neural Mix or additional customization options?
I am planning to use a Pioneer DDJ-400 controller. Is the integration with djay Pro AI on Mac seamless, or are there any known issues I should be aware of? Also; are there any other controllers you’d recommend for use with the Mac version?
How does the workflow on the Mac version compare to the iPad version? Is it easy to adapt; or should I anticipate a learning curve?
Also, I have gone through this post; https://community.algoriddim.com/t/ipad-remote-djay-pro-on-mac-or-ipad-extension-controller-machine-learning which definitely helped me out a lot.
I already have a subscription to djay Pro AI through my Apple ID. Will this carry over to the Mac version; or will I need to repurchase? Also; is it possible to sync my playlists and settings between the two devices easily?
Thanks in advance for your help and assistance.
