I’ve just bought and set up a numark idj pro, I’ve connected my ipad retina with a genuine apple lightning to 30-pin adapter cable. I’m running ios 8. When I switched it on it updated the firmware.
The problem I have is a bass crackling in my speakers and headphones that’s very noticeable, what do I need to do to fix this please?
This happens to mine to, it has to do with the order in which you turn everything on. I usually make sure that the app is fully closed and then plug in the iPad, turn on the idj pro and then launch the app, if I don’t do it in this order, I get that crackling too
My heart sank when I saw that I already had the audio limiter on. So I tried the classic turn it off then back on again and it’s worked a treat cheers
