- Device model (e.g. 2020 iPad Air 4th Gen): MacBook Pro i9 2019
- Version of operating system (e.g. macOS 14.4.1): Tahoe 26.1
- Version of djay (e.g. 5.1.2): 5.5.2
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): flx 10
- Hardware firmware version (e.g. 1.0.1): 1.14 latest for Mac
- Please consider sharing a short video or screenshots to help clarify your issue
When pressing crush then followed by noise on sound colour fx there is a crackling popping noise.
Press crush then noise press crush then noise and repeat
C) EXPECTED RESULTS:
Should be able to press crush effect and noise and not hear cracking or popping
D) ACTUAL RESULTS:
Crackling and popping sound
@Slak_Jaw done. Also pressing space and noise also gives some interference.
