If 2 tracks are loaded from local library and you press iPad lock button music continues if playing. Tracks stay loaded if not playing
If 1 track is loaded from local library and one is loaded from USB OneLibrary and you press iPad lock button music continues if playing.
If both tracks are loaded from USB OneLibrary and they are playing and you press iPad lock button music continues if playing.
If both tracks are loaded from USB OneLibrary and both are paused and you press iPad lock button DJAY crashes. You have to restart the app and re-connect to the USB.
Hi @rishi, sorry to hear you’re experiencing this issue. Our engineering team was able to reproduce this and they’re investigating further. I’ll share more news here when I have it. Thanks!
Wow… good to hear they are on to it so quickly! Thanks for the update.
You’re welcome @rishi
Hi again @rishi, engineering has identified the issue and is working on a fix which should be included in an upcoming update (likely 5.6.1). Thanks!
Thanks for the update! Props to engineering for the quick fix!!!
