Crash while djaying (Win 10)
Hello Lukas,
I also experienced several times of crash while playing Djay pro.
Please refer to attached screen I captured.
And below is the message in English.
I want to escape from anxiety while playing.
Faulting application name: djayPro.exe, Version: 1.0.27467.0, time stamp: 0x5b69bd8f
Faulting module name: Logging.dll, version: 0.2.1706.9, time stamp: 0x593b1568
exception code: 0xc0000602
fault offset: 0x0000521c
faulting process ID: 0xc03c
faulting application start time: 0x01d44c21496bfa3f
faulting application path : C:\Program Files\WindowsApps\59BEBC1A.djayPro_1.0.27467.0_x86__e3tqh12mt5rj6\djayPro.exe
faulting module path: C:\Program Files\WindowsApps\59BEBC1A.djayPro_1.0.27467.0_x86__e3tqh12mt5rj6\Logging.dll
report ID: 9143d359-3e23-4df2-9f38-565d790328ea
Total name of faulting package : 59BEBC1A.djayPro_1.0.27467.0_x86__e3tqh12mt5rj6
we are very sorry to hear that.
Can you please contact us right away via support@algoriddim.com?
Thank you in advance.
Hi guys,
if you have a crash report please send the copied text to us via support@algoriddim.com.
Regarding the wma crashes, we are working on it and will provide a fix as soon as possible.
Your software is NOT perfected for Windows. Why do you sell it if it doesn’t work? Search function does not work, audio cuts out when you use another program, songs load to Deck 2 by default instead of Deck 1. All of these are unacceptable.
Go get Mixxx free online and stop fooling around with this buggy POS.
Hello Lukas,
I sent the emails with files but no answer yet.
Please tell me the progress?
I’m starting to have problems with the app. Whenever I launch now, it doesn’t play any of my music as if it can’t load it up; just a constant loading icon keep appearing as if I have bad signal or something.
It won’t load up any of my songs now…
Crashes whenever i play a wma file and CRASHES whenever i’m pulling stuff from Spotify and throwing a lot of stuff at it!!! Crap
