DJAY on windows is absolutely terrible i cant go 5 minutes without a crash please fix *
Hi @Stephen1, welcome to the Community! When creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
- Can you please also provide more details about what specific events you think might be leading to the crash?
- Are you using streaming services, Neural Mix, Crossfader FX, the Looper, 4 Decks, etc.?
- Are you running any other programs in the background while DJing?
- Are you using a DJ controller? If so, are you using the latest firmware?
- The more details you can provide the easier it will be for me to help you troubleshoot the issue. I hope that helps. Thanks!
