Does the software version compatible with Numark iDJ Pro hardware controller have the “Crate” functionality like the Numark iDJ2 controller deck? If not, are there any plans to incorporate that functionality into the DJ app with or without the Numark iDJ Pro controller? I use the “crate” functionality extensively on gigs with the iDJ2 deck and is a must for me.
Also, Are there any plans for an option for each deck to have it’s own way of handling tracks? Meaning, Deck A can be setup to load the next track whether done manually or by Automix (You must press play to start) and Deck B could be setup to load tracks continuously w/o stopping and the need to press play.
