crates or djay playlists?
hey guys,
i love the app. it’s my gateway into dj-ing…
are you planning to add crates (or custom djay playlists) in the future?
toggling between itunes-djay and syncing the library is very impractical for generating crates/playlists as i am mixing/trying stuff out. this is currently the only feature that makes me want to try another software and i would much rather stay with yours.
thanks.
It would be ideal to have crates implemented from within the app.
You can use the Automix Queue as a “crate”. Tap the small “collapse” icon in the bottom right corner to open the Queue Box. Simply drag and drop the songs into the box.
