Any plans on creating a crate or playlist feature to the IDJ Pro? I know that the auto mix is a good way to separate music on the fly but I was hoping there would be a more permanent solution. It’d be nice to just click on a playlist and already have the songs I need ready to go. I love program otherwise. Keep up the good work and thanks for keeping up with all the updates and bug fixes.
Hi Carlos,
You can also add playlist(s) to the Automix Queue. Does this not work in your case?
How do you automix with VJAY?
