Why does the cross fader turn off the headphones on the side the cross fader is moved to when pre-queuing is enabled? Is there a way to stop this behaviour? I personally like to cue up a track with both turntables in the headphones, however if the cross fader is moved in a bit and then back again it turns off the headphones of that side?
Do you have the iPad version? Tap the cogwheel button, select “Settings” -> “Advanced” and disable “Auto Select”.
Regards,
Warren
