- Please also consider sharing a short video or screenshots to help clarify your suggestion
YOUR SUGGESTION:
- In mapping a controller when used to use a keyboard there was a cut crossfader button and a fast cutting button. Could these be added to map to a controller? I am using the RS1 and i usually customize the button i dont use as much, thank you
I tried mapping to internal mode and most of everything is working just like external mode. except when i move the crossfader completely over one deck cuts out.. other than that its nearly the same with a mappable cut button, instead of using the cross fader, i hope you understand what i meant, i attached some videos
Hi @Dj_Los_Inthemix, the RS1 is an External Mixer Mode only device. I do not recommend setting the Audio to Internal Mixer Mode.
it works perfectly with these settings.. even fixed the crossfader issues…I dont know much about the programming part of it, maybe you can help reach the outcome that im trying to achieve, thank you
That’s great to hear @Dj_Los_Inthemix. If by “programming” you mean MIDI Mapping, we have a dedicated section for this in the user manuals.
