Device model (Macbook Air M4, 24GB RAM, 512GB SSD):
Version of operating system (macOS 15.6):
Version of djay (e.g. 5.4):
Hardware/controllers used (e.g. Rane One):
**As i didn’t found a solution in existing threads i’m kindly asking if there is an option to manual set the cut in point (like in serato) in DJAY to set the crossfader curve with a curve wheel.
I cannot use djay because the curve and cut in point of my innofader in the rane one is always open and it’s not closing at all in all available crossfader curves.
Hi @Slak_Jaw
These are all the curve settings that i already tried and it’s not working.
Could you please implement a manual “curve wheel” to set the curve properly to any fader?
I think the problem is that i have not the stock rane fader in my Rane One. I’m using a mini innofader pro where i set the cut in point manually directly on the fader because otherwise it would bleed in serato when i would move the fader side to side on each side.
So i extended the cut in on the fader and had to turn the wheel to a different point as it was set normally.
