Crossfader Delay
  • Device model (2021 M1 Mac):
  • Version of operating system (macOS Sonoma 14.5):
  • Version of djay (5.1.7):
  • Hardware/controllers used (DDJ SX2):
    Crossfader delay when breaking away from left or right side with fader…I even bought a new crossfader, same issue. ive wrote about this before just hoping maybe a new light can be shined.
Hi @Slim89, can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Please also share some screenshots of your Crossfader Curve Settings in djay. Thanks!
Also could you share the crossfader settings
@Slim89 please also confirm if you are using the built-in MIDI mapping or a custom edit. If using a custom edit, please share screenshots of the advance section of the MIDI mapping for your Crossfader. Thanks.
X-FADER ON SX2 ALL THE WAY TO THE RIGHT NO CUSTOM MAP FOR CURVE
Thanks @Slim89. Try turning Crossfader Cutting Mode Off.
