@Slak_Jaw will the Mixon 8 pro charge your I pad.
@DJ_Faisal yes, it charges the iPad when connected via USB-C
@Slak_Jaw Awesome! Just need a small usb hub to connect external drive. That’s what I’ve been experimenting with switching from iPad to Macbook air without stopping the music. It’s a hassle when you’re doing a pro event. This is where Mixon 8 comes in. I appreciate your input! Ty.
Hello, when I connect reloop Mixon 8 pro directly to I pad pro then it works fine and even charges the I pad pro.
Issues: When I connect Mixon 8 pro to I pad through a usb hub ( so I can connect my external hard drives for music) then it does not map it does how ever charge the I pad pro.
I’d appreciate any suggestions.
@DJ_Faisal see my answer in your other post and on FB.
There’s something weird about this new reloop Mixon 8 pro. There’s no display for the jog wheels. I’ve only had it for a couple of days. Trying to figure it out with reloop tech support. Hoping this is reliable investment. So far I really like it although is large but lightweight. What other similar product that would work.
