Hi team. I think I may of found a bug unless I am doing something wrong. With drum swap loving Crossfader just seems to mute the drums on both sides. On the AI ones vocal, sustain etc I also need to twiddle my eq to reset the drums as they mute.
iPad Pro 12.9 5th edition with 17.1.2
Mixon 8 with latest firmware
Seems to be with iPad you need eq to be in eq move not neural mix. As anyone else experienced this. My iPhone seemed fine but iPad defo issues with Crossfader effects.
Thanks for the video @Dysfunk_DJ! Yeah I’m swamped here all by myself trying to answer everyone. Thanks for the reminder. I’ll share the video with engineering now. Good catch!
Thanks man. Bless you. Keep up the great work. Im using your mapping now. I made edits one with mic and one without. Depending on gig. Totally rocks, even more so now with 5.0. Loving it
Yes I reported this also. It’s only on drum swap. You have to move eq to reset it. All the others are fine it’s just when drum swap is activated it goes weird. Thanks for highlighting also. Hopefully now dev team can sort it as it’s an annoying one.
Yeah I think it’s when you go to drum swap and then try the others they are messed up. If I don’t go to drum swap all others work ok. For me anyway. I tried on my iPhone and all works ok there so maybe it’s iPad specific. Any case like you say it needs sorting. It’s not a deal breaker but I’d like it to be fixed. Strangely enough when switch to reg eq mode it works fine so it’s defo linked to neural mix. All in all I’m loving 5.0. Incredible update. I was showing my friend this morning over breakfast how improved the stems sound.
