Hello,
Can the Crossfader Fusion maintain whatever BPM I assign to both songs, & mix from those two BPMs. It goes to the original of both and then it takes a few seconds to increase the BPM manually. This option would help.
Hello,
I think the Tempo Blend button will do what you want.
Thanks for the reply & help
