Hello, is it possible to use the crossfader fx and tempo blend function with the mappable crossfader of an external mixer?
I try to mapping my Rane Four and the audio routing works fine only as external mixer.
@Papagp the Crossfader FX only work with Internal Mixer Mode. If the Crossfader on the RANE Four is MIDI mappable and you’re using Internal Mode, it should work.
