crossfader is either set to deck 1 deck 2 or middle, no gradual smooth switch, just a jump.
what am I doing wrong?
This has also happened to me with the Denon MC6000 MKII.
I believe there is a problem with the mapping but so far, no one else has been able to confirm this. When the jumping starts, I move my crossfader slightly away from the far left or right and that calms things down.
Considering that this has happened on all three of my controllers, I have eliminated the crossfader as being the problem.
Again, something with the mapping. I have reported this on video several times to the developers, maybe this will help convince them that a problem exists.
Sounds like a broken crossfader on your controller. You could use a MIDI-sniffing tool to see what data your controller is sending to the laptop.
Hi Siggi,
yes this was the problem. While the Crossfader Cutting Mode is being active there are only 3 positions the Crossfade is jumping to.
You can find further informations about Controller Midi Options in the djay Pro Manual (cmd +?) under 5.1 djay Pro menus > MIDI.
Greetings
I don’t have my iPad in front of me but if I recall correctly, there’s an option in the Automix section where you can set how the crossfader transitions from one deck to the other.
Your photo looks like the Mac version but you should still have Automix somewhere.
crossfader only does this when I plug in my hercules dj controller
didint used to do it…
but does now.
its like its stuck on cut…
thanks guys, but I found the problem…
yup, just confusing that there are 3 places for crossfader settings…
but all cool now.
Thx dude. You just helped me.
