I’m usually using djay on my laptop, and I want to snap transition between the two decks, but if I press the arrow key it skips the track a little bit. I’m not using automix. Some sort of crossfade transition thing. How can I turn that off?
Hi Ian,
Is “Auto-Sync BPM” enabled in the Automix settings?
Yes it is!
I turned it off, and now the problem is solved.
Thank you Warren!
