Suggesting an idea for the Cue Point interface. When using a cue point I usually mistake the set cue point button for the jump button. Maybe you can consider hiding the set mutton. Thanks for a great product.
So like a preference setting that either locks or hides the button. Interesting Idea.
I used to do the same thing. It was certainly annoying. But after more flight time you get used to it. Also if you do a lot with Djay you may want to consider an external controller. I would guess a majority of the heavy users all have external controllers and are rarely actually clicking on the screen.
