Cue Point marker not visible anymore when Main Cue is also there
I created this example video. It’s about the the case when the Starter Cue together with one of the 8 other Cues is on the same spot. In these case only the Start Cue is visable and I believe this was different in the previous version. So it might have changed when introducing the new version. Are you aware of that?
I am hoping that the previous way of dealing with those two Cues both on the same place will return again.
  • Device model MacBook Pro 2019
  • Version of operating system Mac OS, Sanoma 14.4.1.
  • Version of djay: 5.2.1
  • Hardware/controllers used: Reloop Mixon 8 Pro
Hi @DJ_Big_Blender,
Thanks for sharing your inquiry.
We are currently in talks with our engineering team as to whether or not this was an intended change or not.
As soon as we receive more information we will share it here.
Hi @DJ_Big_Blender,
I wanted to let you know that this will be fixed in the next release of djay, which is right around the corner.
Please keep an eye out for the update.
Hie @NathanielAlgo.
It’s not in the latest 5.2.3. for Mac is that correct?
