Cue Points 9-16 crashes djay 2
Device: iPhone 15 with iOS 18.3
Apps: Djay 5.4 and Djay 2
When I add a cue point numbered 9 to 16, it causes Djay 2 to crash when you load song that has the cue point 9-16.
Hi @Dj99.x, I was unable to replicate this on my setup.
  1. Are you using a DJ controller? If so, please provide details.
  2. Can you please capture and share a short screen recording of this?
This is what happens
Thanks for the videos @Dj99.x. Since the legacy djay 2 app doesn’t support 16 hot cues this is probably not unexpected behaviour. I will pass this onto the dev team, but given that we not longer support djay 2, I suspect they will recommend that you don’t use hot cues 9-16 if you want to also play these tracks on djay 2.
I think this might be a problem with Djay 2 displaying the cue point as there is only 8 in that version
Have you replicated this and has the same problem occurred?
I don’t have djay 2 anymore as we no longer support it. The issue is most likely the 9-16 hot cue. If you remove them in 5.4, does that solve the issue?
When the cue points were removed it was still crashing
Okay thanks for the additional info.
Actually a short while later the song started working
Excellent. Thanks for the follow up @Dj99.x. For now, I recommend that you don’t use cue points 9-16 in djay 5.4 if you still want to also use djay 2
It also crashes in vjay
Thanks. I’ll let the team know.
