Is there any way to switch quickly Cue Points bank from 1-8 to 9-16 with a shortcut on MacOS ?
Hi @Julien_Apruzzese, you can create a custom keyboard shortcut for this on macOS.
- Please navigate to the djay Settings>Shortcuts
- Then press the desire keyboard combination you want to use.
- Set the Target>Deck 1
- Set the Action>Toggle Cue Point Range
- Repeat for Deck 2.
