Cue points missing from old djay version
I have been using an old version of Djay Pro (v2 i think) on an old mac laptop (2013) I have recently upgraded both the software (v5.6.1) and the laptop (Macbook Pro 16", M4 Pro chip, 48 GB memory, MacOS Sequoia v 15.4.1) and none of the cue-points are showing up/importing when I open the new software. The music tracks are all MP3’s on an external USB drive. Can anyone please advise on how to fix this. Many thanks!
Hi @PigCity, welcome to the Community! Please refer to the linked topic below:
Hi and thanks for the message.
I have tried this numerous times but it’s still not working. Do you have any other ideas please?
Many thanks.
Merlin
You’re welcome @PigCity. Did you copy the djayMediaLibrary file from the djay Pro 2 folder to the new djay folder? Make sure that the djay apps are closed when you do the copy and make sure that you over-write the djayMediaLibrary file in the new djay folder with the old one.
Hi thanks for the reply.
Yes I’ve followed the instructions but none of the cue points are loading in when I open the tracks on my new laptop in Djay pro v5.6.2.
I can see all the meta data files are in the library folder though.
Thank you
Many thanks.
Merlin
Thanks for confirming @PigCity. I can’t think of anything else to suggest. This is the process and there is no alternative unfortunately. Sorry I couldn’t be of more help.
