Cue points & mixer & waveforms switch view
Please add in mapping list switch views from hardware. Right now if i’m in mixer view or în library, etc. i have to press on iPad to switch back on waveforms view.
It will be more easy if we can do this on controller.
Regards
this midi map function exists, i’ll try to send it to you soon
i’m back. so you need to map your button to the following midi :
Music Library / Library Layout / Toogle Library Expanded
it works for me :slight_smile:
Thanks for your help!
But is only for library. For example, if i’m in waveforms mode view and want to switch to mixer mode view (eq, cue points) can do that from controller? Can be mapped?
Regards
