- Device model: Ipad 5th Gen*:
- Version of operating system: Windows 10 and 16.78 OS for Ipad)*
- Version of djay: 5.1.3*
- Hardware/controllers used: DDJ FLX 4*
Your question:
I read how to sync cue points from an Ipad to a mac but I’d like to know how to do it from Ipad to PC.
Can you help ?
Thank you ![:slight_smile: :slight_smile:](https://community.algoriddim.com/images/emoji/apple/slight_smile.png?v=12)
Hi @Maxence_P, currently there is no official way to do this as the djay Media Library for Windows uses a different file name and extension than the iOS version.
Thank you or your answer @Slak_Jaw
Do you think adding Icloud to my computer could do the trick ?
You’re welcome @Maxence_P, iCloud Sync only works between Apple devices. You could look into using a 3rd party solution like Mixo, DJ Conversion Utility or Rekordcloud.
Thanks again for those infos. All those software are rather expensive for a feature you’d expect native in a Djay app ![:confused: :confused:](https://community.algoriddim.com/images/emoji/apple/confused.png?v=12)
Sadly, I’ll probably have to cancel my Djay pro subscription and switch to Rekordbox (which features and UI are far less competitive than Djay pro) since they have a great way of transfering cue points and songs across devices.
I hope Djay pro will get a feature to do it as well in the near future
