Hi from Germany.
once identified a cuepoint is very useful.
- Is it possible to have DJAY search automatically for cue points?
- Can I save them?
- Can I recall/activate them with Hercules DJ RMX?
Thx
Joe
Hi from Germany.
Thx
Joe
Hi Johannes,
(1) What do you mean by “search for cue points”? All available cue points are displayed on the “vinyl” and on the waveforms.
(2) djay saves all cue points automatically for each song
(3) As far as I know, the RMX only has one designated button for a cue point while djay supports a total of 3 cue points + 1 start + 1 end point. You could map other buttons to the other cue points.
