Setup:
Windows 10 Laptop
Original splitter cable
Pioneer DDJ200
Everything pretty much works as it should, with one weird thing.
I’m having a weird issues where the sound from the pre-cue channel on the headphones is also playing on the master output channel on a low volume and vice versa for the cue channel (even though pre-cuing is fully set to cue and not on mix)
If had tried to fix this on multiple occasions but haven’t managed yet so far.
Any pointers to as why this could be? It seems like the signal isn’t properly split into two mono signals.
