Cue turning on for previous song when fading out
Can someone remind me how to turn this off? I seem to have lost where the setting is.
@Tony123 on iOS go to Settings>Sound and turn OFF Auto Select at the bottom. I believe it’s in a similar location on MacOS.
Thank you!
Really appreciate you taking the time to reply
You’re welcome @Tony123. Happy to help.
I just checked, and the setting isn’t there on Mac OSX but it is underneath the “Cue” icon in the menu bar - just leaving here in case others have the same problem!
