Cuepoint + BeatJump trigger... tightening
if this has been already been requested i apologise
The idea behind this suggestion, is so that the cuepoints can be used in conjunction with a beatjump multiples, thereby creating more cuepoints to jump to
the problem i have encountered, is the response time between the cue-point being pressed & the beat jumps being initiated
an example:
cuepoint +beatjump -2 + beatjump -0.5 or again cuepoint + beatjump -2 + beatjump -1
this gives a more precision for beatjump gymnastics if Djay pro could execute this properly
currently the delay in executing a cuepoint with a “single” beatjump leaves a gap for a noticeable audio-gap before the execution is carried out…
adding a additional beatjumps for odd beatjump number makes this currently not possible as the execution of a single cue+beatjump is playing catch-up
there may well be reasons for this inherent delay… ie tempo follow? latency? or other?
…now while this Cuepoint+beatjump gymnastics is better suited to a mapping on a 8x8 pad configuration… a tightening of the delayed cuepoint+beatjump response would be welcome
i suppose to get the gist of beatjump gymnastics just think scratching on cuepoints without scratching
Hi @7nz, Thanks for the suggestion! Could you please try to demo what you’re describing with a short video? I want to make sure I properly communicate this to the dev team. Please upload the video to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here?
In the meantime, please try turning Keylock OFF to see if this helps to reduce the latency.
i will have to try that Keylock “OFF” and see how it behaves
but i will endeavour to get a small video up
Sounds good. Thanks!
heres the demo of the cuepoints + beat jumping with varying numbers
Thanks for the video @7nz. Did turning Keylock off in djay help with the latency you were experiencing? If not, can you please share a similar video showing how this isn’t working as desired in djay? Thanks again!
hi, Slak_Jaw
the best way for the internal djay team or yourself or anyone else to better understand the matter of beatjump tightening…
is to assign 4 midi buttons each to beatjump -0.5 , -1 , -2, -4 & then follow the movements of where the beat jump lands, when dual/triple buttons are pressed
the music doesnt need to be playing, only that you see where the end position should be after a quick dualpress/triplepress…
perhaps the term beatjump tightening is not correct, in that it is more to do with midi button press implementation
thinking about things… this is not a biggie…
as i already have it implemented but within VDJfree, funnily enough doing a midi2key(secret to vdjfree) press conversion with results highlighted in the video
heres the funny thing… i was invested in Traktor, and still have the products on hand
but as i began to explore VDJfree… i found more useful elements which traktor had diffuculty in implementing, although there was a method to provide a dual button workaround… it required the release of the midi button in order 2 trigger a additional midi button… which adds delay to the beatjumping, …also relying on a release to occur, is not practical… when im mashing buttons to keep in time with the drums… after realising this weak point in Traktor, …Traktor made little sense to continue with
contrasting that above scenario with Algoriddim DJpro,
DJpro has the realtime flexible tempo implementation… and this is truely the value aspect of algoriddims DJ app alongside the RT stem separation
anyway enough ramblings LOL
btw i did try the keylock off… results are seemingly the same in that it is a hit&miss affair with triggering multiple beatjumps simultaneously… but i encourage you to carry out the test i wrote above
i imagine this beatjump gymnastics is not something easily carried out on pro controllers… so probably not of interest to many pro users…
but for the show pony’s who have the little 8x8 controllers putting on shows… this is a selling point, even if people dont realise it yet
Okay, thanks for the additional info @7nz. I’ll pass this onto the team.
okay im just providing an update on this beatjump+cue… i have just realised something with regards to this Cuepoint + beatjump
if you adjust the quantise to 1/16… this assists with quick triggerring and responds as it should
however the aspect of dual beat jumps being triggered or triple beatjump buttons being executed remains the same, in that you can only do a Cue + beat jump with a single beatjump button
cheeRs
Thanks for the additional info @7nz. I have passed this onto the team.
Hi @7nz, please update to the recently released 5.3 and let me know if this improves things for you. Thanks!
For the full 5.3 release notes, please refer to the topic below. Thanks!
Hi, i tested the beatjumping aspect… upon carrying out the update 5.3
when i test the response time of quick midi triggerings (quantise 1/16 enabled)
ie. 3simultaneous beatjumps(1+1/2+1/4)
it all responds how it should
however when the cue point is added which precedes the beatjumps…
ie.. Cuepoint + 3simultaneous beatjumps(1+1/2+1/4)
there seems to be a delay… causing the beatjumps to miss their triggering
what i did observe upon testing,
i changed the mapping from “cue point” to “jump to cue point”… thinking that might be the reason for the delay…but themappings effectively behave the same with no difference…
which is odd
becos the “jump to cue point” in theory should not be triggering the play… and this is exactly what occurs, which might be cause of the missed-triggers
perhaps im incorrect in making this assumption that “jump to cue-point” should only move &not execute a brief play response
perhaps a toggle for cue points execute play upon hold/no play response is needed?
Thanks for the feedback @7nz. I’ve shared your comments with the team.
Hi again @7nz, engineering is asking if you could make another quick video demonstrating this, just to be sure they’re understanding fully what you’re referring to. Thanks!
Hi again @7nz, I’m following up on my last message from a few months ago. Are you still experiencing this? If so can you please capture and share a new video? Thanks!
im currently on 5.6.4
and a dual press of 2 midi buttons still doesnt work…
so i just add a slight delay in button presses, which is just a work around…
i still use VirtualDJfree & djay pro simultaneously to get the dualpresses if needed, on my maschine Jam controllers
its not a biggie, i think having the best of both worlds has its advantages! cheeRs
Cool. Thanks for the follow up!
i’ve been revisiting this aspect of cue+beatjumps
there are some improvements on this front, even as the tempo is playing quite fast
basically i have the quantise "on " & set to 1/16
at which point my cue+beatjump comes in correctly… which is absolutely great, i’ve been toying around with things, so please thank the developers, for their efforts!
appreciated!
That’s great to hear! Thanks for letting us know @7nz
